Memory Stick Duo Pro Magic Gate driver
mels
Hello to all,
Finally my vgn-sz2xp works perfectly under Vista !! I still have one last issue though : whenever I put a Duo Pro MS into the built in reader, my PC doesn't detect anything.
I used this reader all the time because I have a PSP ... and now I can't use it anymore. :slight_frown:
What do I need to install or configure for my reader to work ? (please note that the other built in multicard reader works perfectly).
Thanks for your help
Mels
DaveStorey
Hi there,
This problem has been bugging me for a while and seeing as how no one has really answered i thought i would post the solution.
The memory stick vista driver is the same as it was under windows XP. Just download the bundled xp drivers and extrace to c:\drivers. Then manually open device manager and you should see a 'mass storage controller' which has no driver. Just right click and say update driver -> select manual location and point it at c:\drivers.
It will just scan the folders and install the correct one.
You will still need to download the vista registry fix to get the right memory stick icon
Hope this helps
mels
Thank you very much for your reply Dave !
I got mine working as well, but I'm not even sure how :laughing:
