hi, i would like to take my vaio b1vp up to 1gb RAM -
what kind of 512mb memory should i buy?
how hard is the install?
and does it invalidate my warranty?
hope you can help!!!!
thanks
-the swan
Hey Swan,
You should get your memory from www.crucial.com/uk/
Doing this will not invalidate your warranty, as it explains the procedure in the instructions manual.
It's easy to do once you read the instructions.
