MICROPHONE PROBLEM..PLSSS HEEELP
profile.country.el_GR.title
mary-greece
I HAVE A SONY VAIO VGN Z11XN AND THE BUILD IN MICROPHONE DOESNT WORK...PLS CAN YOU HELP? I AM TRYING YO USE IT WITH SKYPE BUT... AT THE CONTROL PANEL, UNDER MICROPHON  APEARS LIKE RELTECK HIGH DEFINITION AUDIO, OPERATING.ANYTHING ELSE.
THANK YOU SO MUCH FOR ANY HELP
pusaqall
Are you sure it has a built-in microphone? Have you tried using a different microphone and see if it will work?
