Missing Power Management Functions, Vaio Control Center
SevenD2
I have a VPCEH1L0E/B and most of the power management functions are missing
http://img21.imageshack.us/img21/819/vaiou.jpg
Its version 4.5.0.03040
All default programs are still installed, and it's running Win7 x64. I've already tried restarting to factory setting and reinstalling Vaio control center with Vaio Care recovery. All my programs are up-to-date with Vaio update
I've also contacted Sony, but no help at all. They didn't answer my question at all.
10 REPLIES 10
rich912
Hi SevenD2,
It is very odd that a factory restore didn’t resolve the problem.
Try reinstalling Sony Shared Library and then Sony Notebook Utilities.
Full instructions for the install are given on the download page for each of these utilities.
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCEH1L0E_B
Rich
Go n-éirí an bóthar leat
SevenD2
Hi Rich
Unfortunaly it didn't solve the problem.
I don't think it did anything.
rich912
Hi SevenD2,
Can you confirm that you have restored your machine to factory settings using either your recovery media or the HDD recovery partition by tapping F10 at boot?
Rich
SevenD2
Hi Rich,
Yeah I used the Vaio care recovery
rich912
Hi SevenD2,
Sorry to appear pedantic but before escalating this to support can you confirm that you have chosen the option, under Vaio Care Recovery, to either restore the C drive or the entire system. I ask this because there are other options that will not restore the Vaio utilities.
Rich
SevenD2
Hi Rich
I chose to restore my hard drive to it's original, factory-installed configuration.
rich912
Thanks for the confirmation SevenD2
Rich
rich912
thread.escalate.auto.reply.message.text
Sallu09
I have the same problem .. did this issue get resolved.
thanks
Sal
