monitor colour profiling - A117s laptop
oxon
How do I manually change the colour settings for my screen
Adobe gamma does not respond - I also have a gretag macbeth device i would like to use?
9 REPLIES 9
Thalamus.
Champion
Hi Oxen,
Welcome to the forum,
To activate the Adobe Gamma Launcher, you first need to calibrate your screen.
The Adobe Gamma control panel should be installed into your program files>common files>Adobe>calibration folder.
Then launch Adobe Gamma.cpl to begin calibarting your monitor.
Let us know how you get on.
I have not used this type of device before?
oxon
Hi Thalamus
Adobe Gamma is in my control panel - it opens but the slider controls do change the colours when moved
Gretag Eye One is a monitor calibration tool - youplace on the screen. You have to be able to manually change the colour settings based on its analysis
oxon
sorry sliders do NOT change colours
Thalamus.
Champion
Click the gamma control (control panel) then select control panel (not step by step) In the gamma section, deselect view gamma only, you should now be presented with RGB settings.
Does that help ?
oxon
Hi
Sorry for late reply
No - I tried this before I entered the forum
I have used this on my desktop ok and used the separate colour manage device - in this case my monitor has a menu where I can manually change contrast and RGB settings
Still cannot find a way with this notebook?
Thalamus.
Champion
Sorry, don't know the english expressions in the pop-up menu.
Try display properties>settings>advanced>ATI Mobility Radeon 9700.
Can you change the settings in there? I do have the same graphics card, look for something like overlay colour controls.
My settings say colour correction, I selected desktop (in the apply colour changes to), as overlay/VMR did not allow gamma settings to be altered.
Hope this makes sense?
S.E.M.
Hi Oxon,
I have the A117S and Adobe Gamma is working the way it should.
And it's not the only way to change colours. When you right-click on your desktop there is a pop-up menu. Continue searching until you find "ATI colour", where you can manually change gamma, brightness and contrast for every colour.
Here's what you should click in german:
Eigenschaften => Einstellungen => erweitert => ATI Farbe
Just to eliminate any possibility of errors:
Did you install the Bios- and Graphics Driver Update and everything else that came with Windows XP SP2?
Greetings,
S.
oxon
Thanks Guys
With both the ATI panel open - colour tab and the Adobe Gamma window open, I can change the Adobe gamma sliders via the ATI colour tab only - weird. Adobe Gamma will NOT operate independently
Its a start many thanks for your help
Thalamus.
Champion
At least you can adjust the settings,
very strange!! :thinking:
