I can't use my Motion Eye. It seems not to work (or I'm doing something wrong). Who can help?
What have you tried?
Are you using Vista? If so what happens if you go to Start -> type 'VAIO Camera Capture Utility' into the SEARCH field and run the program?
What model do you have?
Are you using the original Operating System?
thanks for your reply.
Yes, I'm using Vista. When I run the search I get a list of files which are in ther pc since I bought the PC (I think). Its the AR.
Rgds,
Ger
