My battery!
JamieM
My battery!
Hello,
I am wondering about something that I have noticed with my battery. When I boot up my vaio and the desktop loads my battery (which is fully charged) is at 90%.
I am wondering if this is normal or is there a problem with my battery? Any help would be appreciated. Thanks
~JamieM
Thalamus.
Champion
Hi JamieM,
This has been mentioned several times before, I would think the drain on your battery is due to power used in starting up your Laptop and nothing to be worried about.. :slight_smile:
JamieM
Sorry, and thank you for your quick reply.
Thalamus.
Champion
There's no need to apologise, that was not my intention..
I was only try to make you aware that the battery power loss was a common occurrence..
