My Computer Freezes
1littlestar
My Computer Freezes
Hi, My Vaio Desktop RS 322E would freeze maybe once a week now it seems to freeze twice a day, and it does'nt seem to matter what application i am use.
Can anybody help ?
Many Thanks
13 REPLIES 13
rich912
Hi 1littlestar and welcome.
Have you scanned you machine for viruses and malware?
Go n-éirí an bóthar leat
1littlestar
Hi Rich, Yes i have gave it a full system scan. But nothing was detected.
Kris1990
have you done a disk check for errors
rich912
There are various Hotfixes and updates for your model on Vaio-Link.
If that has no effect then you may wish to consider a system recovery using your recovery disks. Backup your C drive data first as the drive will be formatted during this process.
1littlestar
Thanks for your help, i will download some Hotfixes and then see how that goes.
Cheer's
1littlestar
I have just tried to download 2 hotfixes but was not possible because i have got SP2 which is newer than the dates of the Hotfixes, I guess i could uninstall SP2 but i don't know if that is Possible. Is it possible to uninstall SP 2 without to much trouble ??
kee-lo_
Do you see anything in the error log?
Start > Control Panel > Administration Tools > Event Viewer
1littlestar
Hi Kee-Lo, Great Advice, I never knew about event viewer, 3 Warnings are logged and the sources are : i8042prt and E100B, Followed by Information Tcpip which when opened say's this : The System detected that network adaptor /DEVICE / TCPIP _ ( Followed by my computer numbers ) was disconnected from the network and the adaptors network has been released.
Thanks For Your Help.
kee-lo_
No problem
Might be a good idea to refresh those network drivers
