my FE-21B cant support a pcmcia tv tuner because of the slot size?
giannis_mgr
i was interesting in buying a pcmcia tv tuner the AVERMEDIA AVER TV FM PCMCIA HYBRID ANALOGUE TV & DVB-T CARDBUS.i read in a site that Not suitable for the NEW Express Card 34mm wide slots on some new laptops. Please check that you have a standard Cardbus (PCMCIA) 53mm slot before purchase.i think my FE-21B has the 34mm slot,so it doesnt support most of the types of tv tuner?thank you in advance
You have BOTH slot sizes on your Vaio.
Slot 2 is for PC (PCMCIA) Cards
Slot 3 is for Express Cards.
:wink:
giannis_mgr
thank you very much,i got scared when i saw this kind of limitation.
