MyWay Searchbar Adware
1234567ty
Hi guys, i have somehow got the myway search bar on my system. I have tried to delete it from the progfiles folder, but without succeeding! How do i get rid of it?NAV says it is adware.
12 REPLIES 12
eric_q
try adaware from http://www.lavasoft.de/
software is free
according to them:
"Ad-aware Standard Edition is THE award winning, free*, multicomponent detection and removal utility that consistently leads the industry in safety, user satisfaction, support and reliability."
*Free for non-commercial use only
1234567ty
Thank you eric, but i already have it and it cant delete it!
robpaxton
1234567ty
Thank you Rob, this will hopefully sort the problem out.
eric_q
1234567ty
Got that as well!! I have got the following: HiJackThis, Spybot S&D, Start UP List, Adware 6.0 and No Adware(program, this doesnt mean i dont have any bugs on my system.).
sammiimmas
I have toolbar problems too, personally I use McAfee. But usually can simply get rid of them from going to add/remove programs option (can be found in the startup list or even in the control panel).
Hope this helps
Sammi
Ignore this Thread - IT IS OVER TWO YEARS OLD !!!!
:cry: :cry: :cry: :cry: :cry: :cry: :cry:
jumpsuit
LOL Do you think they got it sorted?
