Need to get a system restore disc for my model vpcf13moe/b toreset to factory default
profile.country.en_IE.title
neal45
I am recieving loads of errors & laptop is running so slow can not seem to get any responce at the moment from Sony how can I get a factory restore disc for my model.
rich912
Hi neal45,
You can order a set of recovery media from Support – follow the link at the top of this page > Contact Sony Support – use the phone contact.
Alternatively try tapping F10, at boot, when you see the Vaio logo. If the HDD recovery partition is intact this should open the recovery utility. Be aware that this will format the hard drive, so first back up any personal data that you need.
Rich
Go n-éirí an bóthar leat
rich912
Hi neal45,
Rich
