New F-Series 3D Laptop, Few problems
Sweedles376
OK so for my birthday i got myself the new F-series vaio laptop.
bought myslef a 3D blu ray, popped it in, turned on my glasses and watched with frustration.
The picture gets pixelated at times and picture seems to be slow like when you stream video
Also im having a problem opening a programme i use. It says use more than 1024 x ??? Res and 96dpi when my laptop is currently running better than this and also doesnt run even when i match the settings. I have tried running in compatability mode with still no luck as a file is supposedly missing on a spanking new laptop
any help?
5 REPLIES 5
What is the exact model you have bought?  Without the model it is difficult to check if there are updates for your Vaio
Have you installed all the Windows and Vaio software updates?  Have you checked that your BD-Drive is running in UDMA Mode?  What version of the Graphics Driver do you have installed?  Is anything else running at the same time that uses CPU power?
I would guess that you are probably going to have to phone Vaio Support to troubleshoot this issue as there could be many causes for BD Video running slowly.
:thinking:
Sweedles376
It is a PCG - 81311M and i dont know how to check for updates
Sorry, that is an invalid model type.  Check on the screen surround or the box for a model starting VPCF22xxxxx
:thinking:
Sweedles376
VPCF 21Z1E
There is an update for WinDVD BD 2D_3D on the support page for your model here: a
http://www.sony.co.uk/support/en/product/VPCF21Z1E_BI/updates
Have you installed this Update?
:smileyblush:
