New Hard Drive Advice Please !
Pedrochellie
I have a Vaio VGN-A417S and the hard drive is faulty - it runs just about ok but i want to replace it with a larger capacity one asap in case it fails completely!
My question is;
My Vaio didn't come with an XP disc or any driver discs - i had to make my own system & application recovery discs when i first turned it on when new.
If i replace the hard drive will the system & application recovery discs i made when i first bought it be sufficient to put windows XP and all the original drivers on the new hard drive?
Thank you for your advice
profile.country.de_DE.title
itbroker
Welcome to ClubVaio PedroChellie :smileygrin: ,
I would like to suggest an external hard disk for you, it's cheap and quick to install. I have 02 (two) myself... A Lacie and Seagate
Regarding your questions...
Normally, your laptop doesn't come with Recovery discs. YOU need to create the discs by yourself.
Instructions step-by-step, you will found by going to My Computer > Vaio C: > Documentation > Documentation and opening the folder for your language
YES
The Recovery Discs will "recover" your laptop to the manufacture setup, like a NEW laptop with ALL drivers and softwares applications.
Pedrochellie
Thanks for your help - much appreciated.
