No sound... Vaio VGN-N21E + XP
pro4s
I've installed Windows XP professional because I'm working at a network. Now the PCI driver, Soundcard and wireless network wont work.. seems no drivers avaiable anywhere... HELP!!!
Hi pro4s and welcome.
You are probably going to find the XP Drivers and Utilities for the N11S are your best bet.
You can download them from HERE AT VAIO-LINK
Have you Installed the Microsoft UAA Bus Driver for high Definition Audio KB888111 first? This allows the sound chip to be recognised and the sound driver to be installed as XP-Pro does not support Hi Definition audio.
If the N11S WiFi drivers don't work, they will be available for download from Intel.
:thinking:
