norton and system restore
bedwell
anybody had problems with system restore while having norton installed, i cant get restore to work properly.
using vista premium on viao nr11s/s
Thalamus.
Champion
Hi bedwell,
yes if Norton is installed on your Vaio it can interfere with System Restore, normally with an "Restoration Incomplete. Your computer cannot be restored" error message, use the following link to view the solution:Norton System restore solution.. :slight_smile:
