Hey out there!
Again another question about my new AR-31M:
Is it possible to attach a notebook lock such as this one to the vaio?
Notebook Lock
There is a statement that the notebook needs a "Standard Lock Slot". Does the vaio have anything like that? I didn't found anything except one small hole on the left side next to the
dvd/rw combo drive...
Edit:
I've got another question too:
After buying this great Notebook i'm quite poor now
Is it possible to run it with another 19V Power Supply?
Such as this one
I mean the original one is shipped with the notebook, but i want to buy an additional one
for traveling.
Hope someone can help me.
Thanx in advance
TheViper
Hi TheViper,
yes it would appear that the security slot is to the front of the dc/dvd drive on the left of your AR..
I'm guessing the casing is the same on the AR31M as is is on the AR21S so apologies if it isn't.
There's a Security Slot on the left hand side just below the Blu-ray Disc sticker. I have no idea if it's standard though.
Hi TheViper,
The security slot on your model and all Vaio Notebooks, to my knowledge, is a standard Kensington security slot so yes the one in the link that you provided will work.
