on my vaio vgn b1xp the led num pad is on : what key to use to turn off ?
thanks
Try pressing the ALT key down and there should be a key with Num Lk on the top. press that.
It's the FN key not ALT
Just tap the "NumLk" key once and that's it. Top row of the keyboard, 4th key from the right.
