My Vaio K115 is overheating all the time. untill it freezes and or the screen backlights turn off if left on overnight.
after puting it on from cold by about 20-30 minutes the fan is then constantly on FULL but the heat build up is abnormal.
I am thinking its the processor going faulty ( a few months ago the fan broke and the temp of the processor reached 90 Degrees Celcius a few times. the fan was replaced , but the processor is still getting very hot ( dont know exactly the temp as the utility for that is no longer installed) but it id definatelly running super hot.
If the processor is faulty, I would like to replace it with the fastest processor that the motherboard will accept
HELP
Hi ali_mahmoud,
Welcome to Club vaio,
To check the temperature of your vaio download and run mobilemeter
Post back the temperatures of your Vaio once you've run mobilemeter..:smileyhappy:
The cause could be a build up of dust and you could be try cleaning the vents with a blast of compressed air..
My laptop is currently running at about 59 , but it has only been on a short time. it will get much hotter in 30 minutes to 1 hour. (the second fan has not even started yet.
WHAT IS THE FASTEST CPU THAT THE VAIO K115Z can accept
thanks
