PCG-SRX41P Loose scren
ian.garrison
Header says it all - my 3y old laptop's screen is getting looser.
Any diy tips on tightening/relpacing?
(PS Why no search function on this forum?)
8 REPLIES 8
kee-lo_
Apparently there are screws under that plastic thing which you can tighten.
I wish they'd get a move on with search too...
ian.garrison
Ummmmm ..... what plastic thing?
kee-lo_
The plastic where the actual hinge is, where it turns 90 degrees to close.
ian.garrison
Sorry to be dense, but I've not done mch with this machine - how do you get access to taking off the plastic covers? Is it a matter of dis-assembling the whole thing (the ~8 philips screws underneath, etc.) , or is it enough to undo the small torx screws under the rubber "feet" and take off the "legs"?
kee-lo_
Correct me if I'm wrong but you have to take off the speaker grill off first, the screws are on the side.
ian.garrison
I think you may be thinking of a different model. The srx41p has 2 tiny speakers in front (nearer the typer) of the keyboard. No screws at the side ....
robpaxton
Have a look at this site - you will have to register but this is free. I believe the nearest model to yours is the PCG-SR27, the manual should give you enough information to be able to disassemble your notebook so that you can examine the hinge assembly and see whether it is adjustable.
ian.garrison
Thanks - I'll give it a shot.
