PCMCIA Standard Power Output
Tiggerbasher
I have an old PCG - FX505 and am looking for details on the standard power output of the PCMCIA slots. I only ask because I have my eye on a card that says it requires at least 1A Standard Power Output from the PCMCIA slot.. Anyone able to help. Thanks.
4 REPLIES 4
profile.country.de_DE.title
seb21__
The standard output of the 32Bit PCMCIA port is always 3.3volts. Not more, not less.
William
Volts is one thing Amperage is very different.:smileywink:
seb21__
Hehe that's true. But if we move us within standard specification then everything should be fine.:smileytongue:
Tiggerbasher
Thanks - will buy the card anyway and see if it works... 1 Amp seems a bit of a big load to draw off 3.3v... hopefully it wont bust into flames...
