PCV-W1/G Power Supply
mike_coreit
Hi does anyone know where I can get a replacement power supply for a PCV-W1/G ?
The current one is a Delta Electronics model. DPS-190BB-1 A
Hi Mike,
First place to try should be Vaio Support to see if they will sell you one.  You will need to use the out of warranty premium phoneline 0905 0310006.
If that is not possible, I think you will need to import one from the US.  Several places seem to have stock but this one advertises international orders: -
http://www.sparepartswarehouse.com/Sony,Computer,Part,146877213.aspx
:wink:
4 REPLIES 4
Hi Mike,
:wink:
rich912
Yes, I know where to get one but it is probably ‘a bit late now’...
Rich
Go n-éirí an bóthar leat
celavey
Go to any stores near you that sells PC parts. You will surely get a power supply from them and in a cheap price.
mike_coreit
Thanks for the tips. I ended up finding a refurbished one on eBay.
