Please help
aurebad
Please help
I have by an sony vaio VGN-N31M from Flamingo Computers, Romania. By mistace i have deleted de recovery partition and i have no cd with the recover. where ca i find the recover disk..or give me a link to downloat it.
6 REPLIES 6
MattWilson
You will have to contactVaio Link and buy some recovery discs.
aurebad
i have try`it with e-support but i haven`t recived any answer.what can i do ?
MattWilson
All i can suggest is that you email them again. There is no way to download the discs. Hopefully you will have more success if you try again!
aurebad
if they don`t answer what i can do... the vaio notebook it`s came whit windows vista.. but i don`t like it.. i have instal windows xp prof. but i can`t find the driver for wireles and firewire.. do you know any link where i can find the driver ?
MattWilson
You can install XP and use the N11M Drivers that are the xp drivers. Download Here.
Note that not all the drivers will be for the correct hardware as you have a newer model but anything that doesn't work after trying this drivers then visit the manufacturers website for the latest XP drivers.
Good luck! :slight_smile:
kee-lo_
You should call Sony for the faster support.
