Plugging in headphones or speakers doesn't disable my laptop's built in speakers
loheslath
When I plug in my speakers or headphones in the jack on my laptop I expect the laptop's own small speakers to stop playing sound. However I get double sound output, both through the plugged in headphones/speakers and the laptop's speakers. I'm running Sony VAIO with Windows Seven.
rich912
Hi loheslath,
There is a hardware switch contained within the speaker jack that should mute the internal speakers. It would seem that this has failed. You could try plugging and unplugging the external speakers rapidly, several times, in the hope that this will free up the switch, but I doubt that this will work.
If the machine is still in warranty contact support, otherwise speak to one of the Sony repair partners.
Rich
Go n-éirí an bóthar leat
