printer problems
cianmcb1
printer problems
I have purchased a lexmark z1420 printer for use with my Viao - The printer installs correctly but it can not cummuniate with printer - - - - HELP
Hi cianmcb1 and welcome.
Are you trying to connect wirelessly or using a USB cable?
If it does not connect wirelessly, try it with a USB printer cable to check all the drivers work OK and then address the wireless connection problem which may be firewall or WiFi security related.
:thinking:
