hi, from a few months, during the use of windows xp, feels a strange beep, from thing it could depend? I am sure that it is the announcer of the pc to produce it.
tell me thanks
installed software :
Dreamveawer 8 , firework 8, flash 8, office 2003, photoshop cs 2, coreldraw x3 suite, outpost 4, kaspersky 6
notebook: Sony vaio PCG-GRT816M/IT1
Yesterday the notebook has given me up to 80 degrees of CPU and 48 degrees of hard disk, however it has always had temperatures so the portable one
1x short beep before boot means everything is OK, in Award BIOS. And Phoenix BIOS version 6, Award and Phonix using same
(My desktop PC beeps if I have connect a USB device. One beep per unknown defice before system boots. Hwo knows why.)
One beep in Windows is not much. I have no idea what does it mean.
You could go into BIOS settings and set them to default. But I'm not sure whether this helps.
Here are two little error-message list. One in German, one in English.
http://www.bios-info.de/qb3k5ylk/phoesign.htm
http://www.hi-tech.net/zones/help-beep.html
As far as I am aware your model has an Intel Pentium 4 processor 2.80 Ghz – please correct me if I am wrong on this.
This is a desktop processor which is designed to run at far lower temperature than a mobile CPU.
The maximum temperature for this processor is approx. 75 deg C – I am surprised that you have not been experiencing system slow down or even shutdown!!
Are they not all beps that feel him to the start of the system?
Does it beep if your start your VAIO? How does it sound?
How does it sound?
doom3,
Your notebook is running far too hot. You need to, initially, clean/clear the cooling vents with compressed air (air duster) – your local PC shop will be able to supply this and advise you how to use it.
If that has no effect (and I am afraid to say that with your model it usually doesn’t), then the notebook will need to be opened to carry out a thorough clean of the cooling system/fan. If you are unfamiliar with disassembly of notebooks then this is best entrusted to a professional.
Beh I didn't want to be to spend other money there... 😞
However the notebook one it is also filled with dust as a desktop ??
I’m uncertain as to what you are saying here, but yes the cooling system is clogged with dust and fibres.
Do I understand, therefore can the beep also be caused from the excessive temperature ?!
