Problem on screen in my VPCEB1S1E
profile.country.GR.title
sta8marxis
       My problem is that the right half of my screen is brighter than the other half! Any help please?
Message was edited by: sta8marxis
Has it always been like this or has it just started?  I am assuming you are looking straight at the centre of the screen?  Does this happen at all different levels of screen brightness?
You can try reinstalling the Graphics Drivers to check that they are not corrupt but I suspect this is a hardware issue and you will need to contact Vaio Support to discuss the way forward.  It may need a repair.
:thinking:
sta8marxis
It started 2-3 days  before, but not so bright difference! I have the latest graphic card drivers, and it happens in all brighten levels!Brightness.jpg
Maybe you can see the difference in that image!
