Problem running my JVC Cam on my FE41s Vaio
moawah
Hi All,
I am facing a problem to download my pictures and video files from my JVC Hard Drive cam on my Vaio FE41s. My vaio operating system is Windows Vista Home premium. Every time I connect the Cam, a window box appears asking for the USB drive software, although I used it before my last system re-instalation without any problems. I serached on the JVC website and I cannot find any USB drive software for the Cam, so I thought the problem is with the computer or the operating sytem. Any ideas will be highly appreciated.
Cheers,
Moa
rich912
Hi Moa,
When the Found New Hardware wizard appears try pointing it in the direction of C:\Windows\inf
Go n-éirí an bóthar leat
