Hi every body !!!
I've a samsung SDH-Z500V, which is connectiong by bluetooth...
Thus, I would like to connect it to my PC, by the bluetooth connection...
But on my PC, bluetooth doesn't work : when I activate it and desactivate LAN (Wifi), an error message appears : "Windows doesn't recognize the USB peripheric you've inserted, click to see the problem..."
Do you know how to manage and fixthe problem ???
Have you tried reinstalling the Bluetooth Device drivers?
What does the problem message say, you mentioned it but didn't post it.
How to reisntall bluetooth device ???
It doesn't figure in the installed components (configuration panel, installed programs).
I've seen on the Net that I need to buy a bluetooth adaptator, which is put on the USB port...
Is it right ???
P.S : sorry for the approximation of my posts, but I use Win XP French version, and not the English one...
Do someone has the same problem ???
Has someone the same problem ?
