Hello,
first of all, I use the original Windows Media Center.
To make DVD I use NERO 6.
It is not possible to make a UDF DVD (DVD+R 8x).
Nero brakes burning bei 90% all times.
I have upgrade the firmware. No helps.
Who knows other solution?
Roman:smileyconfused:
Does it work at a slower speed 4X or 2X?
Does it work using WinDVD for Vaio?
Have you tried another make of disc?
Yes, I have.
I have taken 3 different DVD (+) .
The same result.
It can be burn only with 2x.
I have put a new firmware to DVD.
I does not help.
Roman
