Everytime i switch off my K115, a message tells me that the application "ccApp.exe" cannot turn off. So i have a windows box which turns it down.
What is it? How can i fix it?
Had the same problem, its related to Norton Antivirus.
As it was only a 90day trial I uninstalled and used EZ Armour.
"Associated with Norton AntiVirus 2003, which runs auto-protect and email checking facilities. Without this service, both facilities cannot function correctly."
Yes, as everyone has said, this is a Norton AntiVirus thing - they have some blurb about it on their website.
I had this really annoying problem too. Because it took ages for ccApp to shutdown, my dial-up gateway would always dial out when ever I shut down my computer. But I found a solution... well it works for me. It only occurs when C: drive is low on space so I regularly clean the drive and 'Remove all but the most recent Restore Point'. (This can save over a gigabyte.)
(For what it's worth, my NAV is installed on 😧 drive.)
It might be worth a try.
Cheers,
Chris
Hi Chris, good to see you again
Nice tip, I'll have to test it out.
Hi Kee-Lo - it's nice to see you too (and ain't it changed around here ).
The space saving thing works for me and I don't get that ccApp thing anymore. Just don't ask me why 'cos I don't got a clue.
See ya Kee-Lo,
Chris
Yeah the changes around here have been phenominal.
Hi!
I have the NAV installed by default eith the bundled software but the problem is other: sometimes (not always) using Outlook 2003 when doing a send/receive messages, the CCAPP.EXE goes too 100% CPU usage and all applications stop responding. When I kill the process, no more send/receive's work from Outlook, until I restart the PC. And this began to happen since the last Norton Update....funny ....and, I have 15,5 gb free in my drive C!!
Thats a bit odd.
All I can suggest is searching through Symantec's KB or just doing like everyone else and moving to a better AV, like AVG or Kasperspy.
