Problem with RAM replacement
Audonien
Dear all,
I tried to replace my RAM sticks on my VPC EB2M1E - and failed.
The current ones are native and as following (two of them)Screen Shot 02-06-17 at 04.52 PM.PNG
I bought two Crucial 4 GB DDR3L - 1600 SODIMM 1.35V CL11
None of them worked:
 - when using a single new one or the 2 new ones, laptop reboots after a few secs, even if I try safe mode
Sometimes it doesn't reboot but I get either one of those blue screen error messages :
STOP . 0x0000007E (0xFFFFFFFFC0000005, 0xFFFFF8000293CC43, 0Xfffff880009A90A8, 0xFFFFF880009A8900
or
STOP : 0x0000007 (0xFFFFFFFFC0000005, 0xFFFFF88001959D6E, 0xFFFFF8800D6269, 0xFFFFF8800D626160) - i also got this message earlier when my laptop suddently crashed
 - when using a new one and an old one, almost the same (takes a little bit longer to reboot though)
 - when using the old ones, works as usual
I tried Memtest on the new ones, the laptop reboots every time.
I sent them back to Crucial and they sent me new ones: I get the same effects.
It seems my BIOS is up to date (R0300Y8M 7/20/2010)
Any tips?
0 REPLIES 0
