Problem with VGN-AR31S
profile.country.el_GR.title
julesaugier
Hello,
I am new to vaio but i was just given this sony vaio VGN-AR31S laptop. I updated it to windows 7 but there was a problem : the nvidia GeForce Go 7600 GT card is now registered as simple VGA card and I cannot view HD movies any more. I tried to update the driver with windows, with the official nvidia website but it does not change a thing...
Does anybody have a piece of advice for me?
Thanks and best regards
rich912
Hi julesaugier,
Have you installed Win 7 32 Bit or 64 Bit?
If the former then try installing the Vista driver from the Support site.
http://www.sony.co.uk/support/en/product/VGN-AR31S/updates
If 64 Bit you will need to find a Nvidia driver plus modified INF file for the system to allow installation.
http://www.laptopvideo2go.com/  - Read the quick start guide towards the bottom of the page.
This procedure will of course be at your own risk.
Rich
Go n-éirí an bóthar leat
rich912
Hi julesaugier,
Rich
KatherineYH
First right click on the driver setup file and select " TROUBLESHOOT COMPATIBILITY" option. Tick the program worked in earlier version of windows, click next, then select windows vista, click next and click next again to install the driver.
_______________
The truth is a poor exscuse for lack of imagination http://imagicon.info/cat/12-13/text-smiley.png
