hi everybody,
I got my Vaio FR 315 S with pre-installed os xp home, but unfortunally I had to switch to xp professional.
Since that time, I have probelms with the hotkey functionality,
I have no access to the delivered vaio software, because I cannot run the vaio restore cd and
the touchpad is not working as expected as well ( when I try to do a double click, on the touchpad field, no reaction. I have to use the buttons in front of the touchpad. I tried to reinstall the the driver, but I have no access.
Does anybody no a solution for these or a single probelm?
Thanks in advance.
I called the support but didn't get any response, because an os different to xp home will not be supported.
Thanx to the helpdesk at this point. Good job guys!
