Problems playing Blue Ray on HDTV
Brianstien
Hi all,
I'm trying to connect my FZN21Z to a Samsung HDTV (1080p) - using HDMI cable - to watch Blueray movies.
WinDVD starts to play the movie on the laptop and then stops and displays "Your display environment does not support Protected Content Playback"
Any advice much appreciated!
jeffer
The solution is in the forum if you search.
Make sure you set your laptop to output ONLY to TV, and not both to laptop display and TV.
Hope that helps.
