Problems with USB TV tuner on my PCV-V1/G
fatgaz
Hi
I bought a Pinnacle duo tuner to work with my Viao but even though it installs and works, the picture keeps freezing and juttering! It says that i have a good enough system spec, so why does it do it?!! I have tried buying another tuner but the same thing happens, although in a different way - the other one worked fine but froze for 2 mins every 12 mins!! Hugely frustrating!
Any help would be gratefully received!
G
8 REPLIES 8
robpaxton
Have you got a good aerial? You get the sort of problems you're describing with digital tuners if the aerial isn't up to scratch.
kee-lo_
I have to agree with Rob, when we get heavy rain we get that symtom.
fatgaz
Hi Guys
Thanks for coming back. Re ariel, have a pretty decent one and it delivers fine pictures via gigapocket for the standard channels. Do you think i may still need an ariel booster? Would that do the trick do you think?
Thanks once again
Gareth
robpaxton
Gigapocket is analogue so you can get away with a less good aerial. I would try the system with your main home aerial to see if it's the problem.
kee-lo_
You can get a digital ariel now, but when we asked for a quote it was £139 to have fitted.
robpaxton
I'm pretty sure that there isn't a functional difference between a digital/analogue aerial. Perhaps it just has greater gain . . . .
It sounds like you have a Video Overlay problem to me.
There is a control panel with the card I use (WinTV Nova-T-USB2). I would contact Pinnacle support to see if a similar function exists for your tuner.
:wink:
kee-lo_
Rob to be honest with you I think they were trying to rip us off, that's why I said politely "we'll think about it"
