Dear Anyone..
Can't seem to load photos from Canon Ixus 30 to VGF-AP1L... assume that, according to the instructions, it doesn't support this camera as an error message comes up on the personal player when connected.
Any ideas how I can get my photos (already on PC) onto player? Have Canon photo platform but cannot see way to do it. Would it work similar to music (ie K drive?)...
I'm not sure. Do you connect you Digicam with the VP via USB cable?
Maybe you must activate the "PTP" mode for the USB connection. Then your Digicam is like a TWAIN device and not more a Digicam. But I'm not sure wheter this helps.
Good point Seb.
I've found that I can't get my machine to recognise the camera if I use a USB cable. Works fine with iLink cable though.
Mmmh, I have no problems. But my digital camera is from Sony(I don't have a VP)
But I have noticed that with activated PTP mode, that windows ask me whether I will import the pictures. Because it open the assist for Scanner and Camera devices.
If I use the normal USB-mode, it starts the autostart and ask me what I will do with the memory stick.
I have also noticed that the import via USB cable, is faster as via Memory Stick slot. I think the reason is, that my build in MemoryStick slot is only MemoryStickPro suitable. But it's not a real MemoryStickPro slot. Or the reason is it runs via adapter. Because I use an MemoryStickDuoPro. (oops, out of topic)
I have a FujiFilm Finepix F610 and it works great with VP.
When you connect your camera to your PC, does it come up as a mass storage device? If not, don't think about connecting it to VP.
If you want to transfer your pictures to your VP, first I recommend to read the manual of VP, then I recommend search this forum and find lots of threads with this subject.
But for a quick tip, if you want to be able to see your pics on your VP, you have to create folders like this on your VP's HDD photo folder : "USER-XXX" (you have to name the folder like this, cause VP won't recognise it if you put any name. XXX is a number (000-999))
Good Luck:smileygood_luck:
