product key reqested does not match product key on computer
antralph2
product key on base of laptop computer not accepted as product key requested to open items on computer. Is there any other number I can use?
Thalamus.
Champion
Hi antralph2,
welcome to Questions & Answers..:smileyhappy:
This is a duplicate of your earlier thread dated 17-Jun-2011 please could you use that thread please. Here is a link should you need it -
Product key Number.
Exactly what are you trying to open that requires a Product Key?
As far as I am aware, Windows never asks for the product key on the bottom of the latptop.  That product key is for the OEM version of Windows 7 only.
Are you sure you are not opening the trial versions installed on your Vaio?  Some of these require a Product Key to be purchased to upgrade to the full versions.
:thinking:
Thalamus.
Champion
Hi antralph2,
Product key Number.
