PVC-W1 S Keys not working
chrelvin6
Hi there !
Can anyone help me with my S Keys on my PCV-W1 ? they stopped functioning , I have re set them and they work fine ...until.. I shut down my PC , I have to reset them everytime I switch on. Not a real problem for me but poor old hubby can't access the internet without the S Key ,
Cheers Chrissie 26 :smileygrin: !
5 REPLIES 5
BrianPCVW2
Hi Chrissie, if the S keys don't load at startup, check that the startup shortcut has not been lost. Mine is a PCV-W2 but I guess the S keys are the same.
Go to Start -> All programs -> Startup and you should have a shortcut to "Vaio Action \Setup (Server)" or similar.
If the shortcut is not there you can create it.
Right click on the Start Button, click on Open All Users, double click on Programs, double click on Startup and then select
File -> New -> Shortcut
Type or Browse to
"C:\Program Files\Sony\VAIO Action Setup\VAServ.exe"
and click Next
Type the name "VAIO Action Setup (Server)" and click Finish
The S keys should now start for every user at startup.
Cheers Brian :slight_smile:
Hi Brian,
You took your time finding your way in here!!
Hope that now you are here, you will stick around.
You are very welcome to Club Vaio
:smileygrin:
chrelvin6
Hi Brian
Thanks for your help, seems like I had a missing shortcut as you thought. Followed your instructions, all fine now.
Cheers Chrissie :smileygrin:
Thalamus.
Champion
Hi Brian,
Welcome to Club Vaio, nice solution for a first post.. :slight_smile:
BrianPCVW2
Hi folks and thanks for the welcome.
Happy that worked out for you Chrissie. :slight_smile:
I wandered in here because I am having trouble with Click to DVD and the e-support is getting me nowhere :devil:
I checked the forum to see if anyone else had similar trouble but didn't find any pointers so I'll start a thread.
Cheers, Brian
