Questions about VAIO FE28H
profile.country.es_ES.title
dagonas
Hi
i have two questions
1) After reinstalling Windows XP, i install some vaio utilities from the other recover dvd. When i launch them, it reports me that my notebook is not a Vaio
And the other one,
I have full charged the battery. Then, i switched on the vaio and the blue battery icon reported me 91% of charge
Please, help me
Thanks to all!
Gracias a todos!
Thalamus.
Champion
Hi dagonas
Did you use the Vaio recovery tool or install your own copy of Windows XP... :thinking:
I would think the drain on your battery is due to power used in starting up your Laptop, but if your worried then you could check with vaio-link
dagonas
Thnx for your answer
I have installed win xp from a copy of my own
I don't use the recovery tool, because i don't like windows media center
Greetings
