"Fn" is locked :-(
4daS
"Fn" is locked :-(
Hi
I just want to knox how to unlock the "Fn" key
thanx in advance
4daS
rich912
Hi 4daS and welcome to the forum.
As far as I know the Fn key can neither be locked or unlocked. Is your problem that incorrect characters are appearing when you press a key? If so, check the NumLk status. If it is enabled then turn it of by pressing the NumLk key. With NumLk enabled the character on the edge of a key will be displayed on the screen.
Go n-éirí an bóthar leat
4daS
Yes that's it !!
thanx a lot !
rich912
That is good news:smileyhappy:
