I have upgraded to 1024 MB RAM but the System shows only 128 MB. I tested with Tweak, tune-up etc. - it just shows 128 MB. I checked also the hardware. Can anyone help?
Maroni
Hi Maroni,
Welcome to Club Vaio,
Did you replace the original memory modules or just add some more RAM?
Also what Vaio model do you have.
Hi Thalamus,
I have the model Vaio PCV-RSM22 (2,8 Ghz P4/HT).
We replaced the original memory and added 1x 512 MB und 2 x 256 MB, so 1024 MB. The funny story is that Sony Diagnostic shows me 1280 MB but all otherDiagnostic Tools 128 MB!
In any way I want to upgrade now fully to 2048 MB. Can you advice me please what Moduls to buy?
According to Sony it must be 333 Mhz DDR-DIMM!
Anyway thanks for your assistance!
Maroni
I think the problem is you've mixed memory, try with just the 1x512MB
I'm not sure if the memory in your model is paired - you may need all modules the same,
Have a look here for compatible modules:
CRUCIAL
At a guess, you probably need 4 X 512MB DDR PC3200 DDR400
This particular model has 4 banks of 1 which means that you can install one module at time but for best performance they should be paired. The anomaly with reported memory may possibly be caused by the fact that the modules are not paired but I am surmising here….
