RAM Upgrade
fergadeth
RAM Upgrade
How easy is it to upgrade the RAM on a vaio laptop?
Does it have to be dony by a sony approved engineer?
If i do it myself, will this affect the warranty?
Thalamus.
Champion
Hi fergadeth,
Several members have found Crucial.com a good place to purchase new RAM, as I do not know your model I can't guide you further..
Now to the warranty as there is a guide in the manual on how to change the RAM, I would say no it would not void your warranty, however to be safe if you need to make a warranty claim simply remove the new RAM before contacting Sony.. :devil:
fergadeth
thanks for that
the model number is vgn-FS515E
Thalamus.
Champion
Hi fergadeth,
Here is a link for the compatible modules crucial recommend for your FS515E..
Also here is a guide on how to How to upgrade your Vaio's memory
