RECOVERY DISKS
jomacava
RECOVERY DISKS
Where / how can I get a VAIO GRT 800 Series Documentation & Recovery Disk?
Thalamus.
Champion
Hi jomacava,
welcome to Questions & Answers..:smileyhappy:
What is your exact GRT model as you should be able to find user guide on the vaio support site - VAIO After-Sales Support
As to recovery disc's....
You may be able to purchase a set of recovery discs from  Vaio support..
You can find the contact details  for vaio support by either clicking Support at the top of this page or  by using the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then next Select Model..
Then click Log-In
Once logged select Get In Touch.
Then Click on the Out of Warranty tab, then Phone support.
4 REPLIES 4
Thalamus.
Champion
Hi jomacava,
Then click Log-In
jomacava
Thank you for your reply.
Documentation : I know, I have that on the notebook itself, which is a GRT816S. I have also downloaded a PDF version of the Hardware and Software Guides.
Recovery ; I have been through the various stages that you mentioned at Sony Support Europe, and as the notebook is out of warranty, it appears so far at least that no such disks are now available from them. However, I note the telephone number that you give, which I have not tried so far.
Thalamus.
Champion
You're welcome, hope all goes well..:smileyhappy:
profile.country.da_DK.title
Crazymonkey-dk
I will send the reperationen case number when i get home, but i did not update well. It cannot update anything, not drivers, not program or anything. Its pop up with a dialog box, and say that thcere are an error. But i have contactet the danish support, and are trying to figure it out :wink:
