Reduced problem on VAIO FS415S
BashParsi
Hi I have purchased FS415S a month back. There is a problem with my Audio. I am getting very reduced volume even at max. volume settings. Even after calling SONY SERVICE i didnt got any resolution. Is this the problem with all the VAIO laptops?
5 REPLIES 5
kee-lo_
Sounds like a common problem, is this usually during DVD playback? DVDs volumes are not that great, you need to use the booster in WinDVD
BashParsi
I am getting this problem even if i play some thing from my HDD.
When I set the volume to +12DB in some of the applications like iTunes I am getting the volume as expected. Dont know when I called sony they asked me to restore the factory settings... but even that did nt work.
kee-lo_
Yeah it's poor amplification on those speakers
BashParsi
Is there a way to correct this problem ?
kee-lo_
External speakers, or you could try VLC (www.videolan.com)
