Regarding Compatible Battery Model for Sony Vaio VPCEA2S1E
profile.country.sv_SE.title
fadubhai
Hi, I have a Sony Vaio VPCEA2S1E Model laptop. I need to know which battery models are compatible with this model?
As I need to change my battery. My current battery model is VGP-BPS22. Does it support VGP-BPS26A?
As I found that, the diemension of VGP-BPS26A is (272 x 21 x 50) whereas the diemension of VGP-BPS22 is (272 x 20.7 x50)
smart2014
Hi there
Could you please kindly tell us your laptop model and the part number of your old battery as well as the Voltage,Current,Capacity in order that we can double check the compatibility for you?
It will be better if you can provide me some pictures of the battery.
According to your information. we have found the battery which is compatible with your computer.
Please refer the following link and choose the one you like.
[Links removed by moderator for advertising concerns]
Please be free to use our product, we will provide the best sercive and quality assurance. Thanks
B,Rgds Fiona
fadubhai
Hi there,
My model is clearly written in the heading. I was wondering why you did not notice that? All  the information I have written very clearly. If you have a look, you will get the idea. Thank you.
