remote comander not working
kasattack
hello
i have an ar11s, my remote comander is not working, the red light comes on when i push a button on the comander but nothing happens on screen.
can anyone help?
thanks
4 REPLIES 4
Dekesh
the remote commander only works when using the windows media centre software. you can only control volume, muting and possibly a couple of other things whilst not using media centre
kasattack
yes, i was in media centre watching tv, the comander does nothing.
Leohund
I have the same problem ....
rog3rt
Mine too... has worked okay for almost a month and then just stopped. changed batteries and rebooted. even took batteries out and discharged remote by pushing button for ten secs and then replaced batteries. disapointed there is not a solution yet...
