Replace processor in SZ notebook
g-spot
Hi all
Do you think it is possible/feasible/wise to replace the Core Duo processor in my SZ laptop with a Core 2 Duo processor.
Stephen
5 REPLIES 5
kee-lo_
I don't think it's wise because they are different
MauiMauer
Are you that sure Kee-Loo?
The Core 2 Duo (Mobile Version) uses the same socket and chipset as the Core Duo CPUs.
So it is a matter of the used BIOS if the NB will boot with a Core 2 Duo installed.
I'm not quite sure if it was a SZ, but I already read an article of some guy who actually put a Core 2 Duo in his Sony VAIO NB. And guess what, it worked!
g-spot
Thanks for your replies. Are there manuals that show how to remove the processor from an SZ laptop
philfree
The CPU is not socketed, it's soldered.
g-spot
Ah! Well that decides it then... I wont bother...
