Replacement Power Adapter for my Laptop (model PCG-7134M)
huggy25
I need to replace the power adapter/charger for my laptop. Looking on the Sony website I cannot find which one i need.
I am confused as there appear to loads out there on the available on the web and all seem to be suitable  but they all seem to have slightly different specs to the one that I have which is model VGP-AC19V13.
Can someone please advise the genuine Sony replacement model number ?
Thanks.
Message was edited by: Blencogo
To remove Serial Number
Hi huggy25 and welcome.
It would help if you find the correct Vaio Model - have a look on the screen surround for something like VGN-NR***.  I think you are quoting the chassis model which is shared by several different Vaio Models.
Once you find the correct Vaio Model you will probably find a genuine Sony power supply on Amazon - have a look at this one: -
http://www.amazon.co.uk/Genuine-Original-VGN-NR21M-VGN-NR32L-Warranty/dp/B004MZSG5U/ref=pd_sim_sbs_c...
:wink:
:wink:
danhague
I think thats the power adapter model. Check this out, it is the same model with yur power adapater. http://imagicon.info/cat/12-13/vbulletin-smile.gif
http://www.amazon.com/Compatible-Sony-VGP-AC19V13-Adapter-Charger/dp/B0050DNIZ6
huggy25
Hi Blencogo,
Many thanks for your response, you have solved my problem...quite easy really wasn`t it, its just knowing where to look.
