Require replacement / oringinal battery for VGN-FZ38M
pvsrsatish
I really require to get a replacement battery fro VGN-FZ38M battery part is VGP-BPS8A.
I searched various site on-line but not sure as i really would like to get genuine original part.
Thalamus.
Champion
Hi pvsrsatish,
welcome to Club VAIO.. :slight_smile:
You may be able to order a a new battery for your FZ via Sony Vaio support,to find the contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list, in your case VGC V.
Then next to Select Model - select V2S
Then click Log-In
Once logged select Get In Touch
