Restore point
tabaheights
Restore point
Please help I cannot create a restore point on my VGC RA 304, also I cannot restore to a date where there is one?
7 REPLIES 7
kee-lo_
What error message do you get Derek?
tabaheights
I dont know what is the exact message but it just reverts to the currant condition, I am not experiencing any problems at the moment it's just concerns me that should I have to revert to a point in the past I will not be able to.
Hi Derek,
It sounds like the drive log table may have become corrupted. You may find some Tips and Tricks here: -
Tips and Tricks with System Restore
If all else fails, you may have to reinstall System Restore from C:\WINDOWS\Inf
How to Reinstall System Restore
:wink:
tabaheights
Many thanks for that much appreciated.
Hope it works.
The other common cause is Norton (surprise, surprise) if you are using it.
If you are using a Norton Product, you may have to temporarily turn off the feature "Turn on protection for my Symantec product".
Yet another reason not to use Norton
:slight_frown:
tabaheights
Hope it works.
:slight_frown:
What other solution to Norton would you reccomend?
Thalamus.
Champion
Hi Derek,
you may find the What is the best anti-virus programme for Vaio? thread of interest.. :slight_smile:
